Driftworks poly bushes now in stock
james
Administrator
Staff member
We now have Driftworks Poly bushes in stock for most RWD Nissans :)
At the moment we have the bushes for all of the rear arms, we've got poly rear subframe bushes with us any day now and front lower arm bushes are on the way :)
We've given them a good testing out on Phil, Julian and Ant's car and have been very happy with the results :smokin:
Prices are approx 50% of what Powerflex charge too ;)
You can find them in our suspension section
take it you dont do anything Toyota - AE86??
Interested in the Anti roll bar busings and front arm busings also.
AE86 rear arm bushes are nearly done. We've had some fitted to Kenny's car for a while now and they've tightened up his rear end a treat :wack:
They needed a bit of adjustment to get them perfect, but that's pretty much sorted now :smash: :wack:
I'll see what we can do about ARB and front arm bushes for the AE86 too :thumbs:
Well its just the front parts I need really.
You see, I have rose jointed 4 link and adj panard rod so its really just the front end I am after as I have camber adj top mounts aswell.
Anyway, keep me posted and let me know if you need someone to 'test' any parts :)
Adam
W've got a pair of S13 TC bushes knocking about if someone wants em, but I doubt we'll be doing them ourselves in poly
wad said:
How much for a set for my s13 dude?
That depends on whether you have any adjustable rear suspension arms fitted as then one end is replaced with a solid pillowball bearing and you don't need a polybush.
If you've got all standard arms you'll need:
4 x lower arm bushes @ £8.50 each
10 x other arm bushes @ £8 each
That only leaves the subframe end of the toe arms. We don't have poly bushes for those yet as most people would ultimately want to fit adjustable toe arms, but we can supply uprated Nismo toe arm bushes if you like.
If you've fitted adjustable camber and toe arms, you'll need
8 x other arms bushes
if you fitted adjustable traction arms too (not that many people bother) you'll need 6 x other arm bushes.
I reckon we'll look at doing a price for a kit if people want to do the lot :)
