Driftworks SR20 Braided Turbo Hoses
Mark_D
Active Member
Guys,
You used to do an SR20 braided turbo hoses kit. This wasn't so long ago as a mate only bought his from you a couple of months ago.
Do you still do these? If so, any reason only the CA18 ones are showing up on the shop?
Cheers,
Mark
Hi Mark,
Glitch with the shop, if you select the s13 ones, then state in the order notes that you require s14 we'll make sure those are sent :)
Cheers, Kam.
Hi Mark,
Cheers, Kam.
Top man! Cheers :thumbs:
While i'm here - could you check if you have any in stock currently. If possible could you confirm that the set still includes the washers/screws!
Thanks,
Mark :D
In stock, comes with the bolts and washers!
If you let me know the order number, I'll make 10000% sure we send out the s14 ones - also, put in the notes if its VVT or Redtop :)
