Wanted Drivers side bride seat rail for na mx5
haydomiata
As the title, I'm looking for a seat rail to fit a bride in my mx5 or if people know is there much work to put it on the standard rail. It's a recliner so it needs to be base mount. Cheers
I had a bride brix in my mx5, all you need to do is make some brackets for the seat to bolt too, and then bolt that to the seat rail as from memory the seat bolts are spaced wider than that standard seat ones.
It's not that hard to do just use some 3mm steel and it should be fine :)
