royal
S1- F.T break!
Hi guys,
I've fitted the traction arms, the last of my driftworks adjustables, over the last couple of days. They are looking very sexual I've been looking at the alignement and wondered if I could pick your brains for a sanity check.
I've been running the arms widened a bit for the last 6mths but couldn't go any wider because I was getting quite bad bumpsteer with the stock traction arms. Now that the traction arms are fitted I've been trying to work out the best way of setting it up.
I've widened the lower and upper arms as far as they will go. The upper camber arm gets as far as it will go before the others. I've set it for roughly -1 neg camber.
I made up a pikey diy thing to show how much bumpsteer I was getting as I lifted and dropped the car on the jack with the coilovers removed.
It seemed to get less bumpsteer if I had the traction arms as short as they would go. Does this sound right? Just wanted a sanity check as it wasn't what I expected and my amazing contraption was rather 'DIY'.
Sorry if I've got terms wrong, just trying to work it out as I go!
