DW braided brake lines for my e36 coupe?
PJ-R
Ive accidently snapped one of the copper brake line at the point where it screws into the hydraulic brake.
do you do the:dw: braided lines for bmw`s or can they be adapted to fit my car
both the braided line x2 adaptors provided do not fit my hydro brakes 0.7 master cylinder:cry:
do you have any that fit?
What handbrake do you have?? I've got to admit I've never seen a handbrake cylinder that doesn't use the same universal sizes. Are you sure you're connecting the correct fittings to the correct part??
Input line...
Metric fitting goes to brake master cylinder.
Imperial fitting goes to REAR port of handbrake cylinder.
Output line...
Imperial fitting goes to FRONT port of handbrake cylinder
Metric fitting goes to rear t-peice on car.
I have tried fitting it the same way you stated above:confused:
the hand brake was from demon tweeks:confused:
its funny but if you turn the adaptor round the metric side screws in to any of the cylinder ports nicely but it wont attach to the hose then:(
maybe i need to get a new master cylinder as its not the best any more
