DW clutch line question...
Gorman
loop the loop
Recieved my DW clutch line yesterday, its waaaaay longer than the original, is it meant to be like that??
I helped a mate fit one of these recently - it was long but worked just fine.
Are you getting rid of the unneccessary loop?
Hi there! It should be the correct length to remove the original line altogether, rather than just the existing rubber peice. :) If you have to coil it up then you've not replaced enough of the original line!
