DW S13 Front Lower Arm Question
Dave
Me and a mate fitted your lovely front lower arms to my s13, but we have been unable to find out how to mount my Whiteline ARB to the arm. Any insight you can provide on how to connect the two would be appreciated!
I have my lower arms really wide so my (standard) arb has the drop links switched around onto the outside and it fits just right.
I also had problems connecting the ARb droplink to the adjustable lower arm in my s14a. ( i have standard ARB) Now it is connected in a quite big angle (so not perpendicular), the connecting point seems to be too wide outside for my stock ARB wideness....Are these Whiteline ARBs wider than stock ones?
Any one know how to solve my connection problem
thanks
And another thing is, that do i need to push out the studs from my adjustable tension rod to fit it to the DW adj. lower arm with the new studs, that are included in the package?
Otherwise i should create new nuts, as the thread on the tenson rod studs are not compatible with included nuts.
thanks
It depends on what tension rods you have, but generally a vice and a socket bigger than the end of the stud will work, or a big hammer! :)
The whiteline arbs are able to go wider with their droplinks than stock, the lower arms arms do extend the ARB droplinks as far as possible, it gives some additional stiffness to the front bar by giving the front arm less leverage. Stock droplinks DO work, they just sit at an angle.
