e28 3.5 manual
K10RFT
hi all
getting another shed, the car has an electrical prob, rev/drift it hard and it stalls changed everything(well the obvious parts) like afm,fuel pump,service parts, brand new alternator and the likes, seems to be a prob with wiring somewere(cant find it)
the car is std with welded diff, for all of the 1 min that you can drift the car has potential and does go well, it has no mot or tax, needs a fair bit o work
the scrappies gives £80 for a car so if any one want it or parts let me know
K
Why did you have to be in Scotland!! I would have had it for spares if you were closer.
Did you try changing the in tank fuel pump as well as the in-line external pump? Quite a common problem area afaik.
yeh tried those aswell looks to be electrical as the windows also play up i want to find another e28 so i can keep it for spairs:D
K
Sounds like the best plan. I would frag it anyway. Keep the good bits for spares and weigh in the shell (you would get £80 for the shell down here atm) and then if you don't get another one ebay the good bits.
Like I said if it was closer to home I would have it for bits.
