E30 325i Touring
BreadBin
Rough Tonguer
Alpine White
132k
Some history
T&T til August
Good points:-
BBS 15" with almost new tyres, BBS spare too
Recaro seats (drivers is worn but still functional - no foam hanging out)
Mtech wheel
Load cover, toolkit, plastic spanner for BBS centre caps all present
Brand new heavy duty battery with 4 yr guarantee
Kenwood CD HU
Bad points:-
Rust to both front wings and tailgate
Exhaust is blowing
Has a slight clunk in steering sometimes - pair of new track rod ends included which may help to sort this?
Intermittent running problem where it revs itself to 2krpm - splutters and blows black smoke (overfuelling) if you try and rev it whilst it is doing this. This problem only occurs when it is hot and I'm pretty sure it's a sensor, it has been suggested the crank sensor is a good place to start....
Runs poorly at low speed/light throttle - probably an air leak or inlet manifold gasket
Intermittent ABS sensor
Noisy diff
Comes with spare AFM, ICV and other odd bits
Brand new Dist. cap, Rotor arm and 8 spark plugs included (not fitted) - pretty sure they are NGK plugs.
£450 anyone?
