I am looking for a bit of advice on fitting a set of alloys I want on the E30 they are sized.
8.5J with ET15 17"
The front 5 stud set up will consist of the normal M3 Evo gear to keep the wheel centered does anyone know if these wheels will fit up front ok or will arches need to be rolled, For extra brownie points does anyone know a good tyre size to fit.
Now the rear I understand there is a few options of axles to use but really I want to know if the compact one will be ok (due to being the cheapest) If not then hopefully there will be an axle out there sufficient that I will be more than happy to save that little extra to get.
I am looking to fit these without rolling arches but will not rule that out if needs be to make them fit as long as it's not too extreme.
8.5J with ET15 17"
