This is kinda a follow up to my emissions problems as i think the 2 are linked...
When my 530 is cold it will run fine, smooth and pull like a train... when the temp gets up however it will misfire like mad, hunt for idle and hold back when moving under 3k revs.. end result is that when it comes to the emissions test you cant hold it at the required RPM and it fails on HC (Unburnt fuel).
So far I have:
Changed the Lambada sensors,
New intake gaskets,
New rubber sealing bung on the intake
Cleaned the ICV and checked that it "buzzes"
Changed the White temp sensor behind the intake.
Had the injectors serviced and ultrasonic cleaned.
Changed the fuel filter.
Anyone any ideas what to try next? its booked in for bmw diagnostics on Monday afternoon to check the sensors ect out.
This all seemed to start after I changed the back box from the old one to a more free-flowing one, now I have read that you need to reset the ecu (disconnect the battery's and join the to leads together for 10 minutes) as after a while it wont self learn and will use settings that no longer apply... so I might try this after the diagnostics...
Anyone any other ideas?
So far I have:
New intake gaskets,
