pitesy
Hi!
I was looking for some anti roll bar upgrade to my 325i, without going the adjustable eibach, etc., way. On realoem I found this:
316i, 318i, 318is: stock 23,5mm in front, 15mm rear. M-tech arbs: 26mm, 18mm.
325i, 328i: stock front 24mm, rear 15mm. M-tech arbs: 25,5mm, 18mm.
My question is: are the 26mm arbs stiffer than my 24mm stock? It's weird seeing them on a 316i.. The engine is much lighter too, so it isn't reasonable. Or should I bin the idea and save up for adjustables? The first idea would cost about 30 pounds.
Thanks in advance!
Thanks in advance!
