Hi!
I installed hydro to a -98 e36 328 and im having trouble to get the rear wheels to lock.
Cylinder is 0.625 and its installed between master cylinder and abs pump.
Brakes feel solid but handbrake does not lock the wheels and pulling the handbrake pushes brake pedal up and vice versa.
Ive ran close to 5 litres through the system trying to bleed it, tried with vacuum, pumping pedal, pumping pedal and hydro etc.
I have no more ideas other than the abs pump is faulty or a valve is stuck
