e36 less roll needed!
I'm under the impression that the shocks on ebay coilovers are pretty stiff compared to the springs so you could change the sprigs to something stiffer up front.
For the back it's probably easier to find a decent arb
Nothing is good about ebay coilovers except the price and the lowness. They are your problem, you need to buy some proper coilovers or as said, increase the spring rates however, you'll still have bad damping and miss matched shocks. It'll still work though.
I found my Ebay shit worked better when the car was actually raised up to a reasonable level, but thats about as cool as walking in dog shit.
So yeah. Good coilovers, heavy spring rates 8kg/mm as a minimum.
Important: quality Coilovers, Strut Bars front and back as minimum, x brace would help too.
This should be enough. if you still need less Bodyroll you can consider a anti roll kit.
Don't fit an anti roll kit to your wobbly Springs, that should really be the worst driving ever. It would feel like no springs at all in corners.
Spring rates front 9kg, back 9,5kg. ;)
