Jackula
Alright chaps
New to the forum and only been attempting drifts for the last 6-8 months on and off in between the car being broken or me working.
My issue is I can't CONSISTENTLY get skidding in 2nd gear.
I drive a e46 325 with a welded diff, hsd coils and a couple of other minor mods like camber arms etc
I thought the problem was to do with the wheels I was running ( fairly heavy bbs reps 18" x 8 front 18" x 9 rear)
But having recently changed to a set of MUCH lighter 17" x8 front & rear wheels I still cant consistently get sideways around corners
I've got 225/45 all around ns2rs up front and some budgets on back
40psi on rear
No problem doing burnies in 1st, spins up a treat after dropping the clutch. But in second trying to go around a corner after kicking the clutch it just seems to rev and does not spin up the wheels or put any power down to the ground
Is there a power issue?
Could my clutch be fucked so I'm not able to kick it properly?
Are the wheels still to big?
Not enough psi?
Am I being a pansy and not flicking it in enough?
Any help appreciated folks ️
40psi on rear
Not enough psi?
