Bit random but if anyones after fish tank i have one up for grabs. It comes with all the things you need; Filter, Heater, Light, water treatment solution, Bog wood and gravel, scrapper and loads of other crap. I used to have a load of piranhas in it but they eventually ate each other.
Its 4ft x 1ftm but the exact size of the actual tank is 122cm wide x 30cm depth. And the stand with the tank on is 126 height x 128cm width at its widest but the bottom part as you can see is narrower than the rest.
After £100 collected from Birmingham
Cheers
Cheers
