errrr before i go void the Warranty....
Clive
Active Member
is it ok to drill the lower mounts on s13 coilovers so they can except the s14 bolts due to the car rolling on s14 hubs.
Many thanks :thumbs:
I can't, but any machine shop could do it in like 5mins.. I had some made for mine..
OR
get some copper tube from BandQ as there is a size they sell that firts perfectly :D go up there with a vernier and just messure it until you find it :D i Know loads of people that have done that. :)
The plus side of using the smaller bolts is that you get more range of travel on the king pin :thumbs:
15mm stainless from b&q, cut it into sections same thickness as the hub (obviously)
And then I cut a slit in it length ways as its obviously a bit big at 15mm. knock it in to the hubs and job done. :thumbs:
I'd stick some in the post for you but I've used the last of my stainless tube, sent quite a few sets out to people that were unsure.
