fc rx7 turbo II with 1uz swap
rx7cris
hello , i´m doing a swap of a 1uz-fe into a fc rx7 1991 model, I´m doing twin turbos , twin garrets gt 28 r witch are good for 30 psi each, so i believe that i can get easily 500 whp with new pistons and bigger injectors , most likely the 550 cc from the 13 b rotary engine of the rx7. a tuner as told me that the forged internals are perfectly good for 500 whp or more, as a gearbox i´ll be using a zf 6speed gearbox from a bmw witch i found a tuner in the UK that builds adapter kits with flywheel,clutch and adapter plate for this swap , my question for this group is if you have any advise helping me to choose better components or setup or anything actually that can help at this point, i know that there are people that have done this kind of swap and i really need you´re input on this,
thank you
thank you
Re-quoted for visibility.
