cr33ch Broken... Oct 18, 2010 #1 Hello, Do the Nissan £2 spacers fit the Madza tie rod? Its not under mazda suspension so at a guess no... Can you recommend me any? Cheers Alex
DtheBUK Active Member Oct 19, 2010 #2 I know they fit MX5's. If their steering set up is the same size as the fc then yes. Additionally FC3s pro say the max thickness is 6mm where as the dw ones are 3.3mm disclaimer: don't go fitting 6mm spacers before looking it up!
DtheBUK Active Member Oct 19, 2010 #4 Well doubt anyones gunna know. I'd just get it apart and measure, or for the sake of 2 quid, give em a try.
cr33ch Broken... Oct 19, 2010 #5 someones offered me a 6mm fc3s spacer fora tenner so im gonna give that ago
kam I've touched Chris Parry Oct 20, 2010 #7 If they are M16, they'll fit the tie rods. I cant tell you for sure if they will work/fit the rack etc... but it should be fine.
