FC3s tie rods
S14DST
Hey everyone!
As i'm building a pro-am drift FC I need to know what tie rods do you you when making a wider track at the front?
For me it looks like about 10cm wider per side...
I think BMW has the same inner thread M14x1.5, but they are short as hell... anyone uses something off the shelf ''factory'' tie rods? I just don't want to spend 150quid on expensive tie rods and bend them at first training session!
I welded 4 nuts together and onto the tie-rod ends. You should never put welds in tension, but iv'e done 5 events on them and they haven't broken. You probably shouldn't do this lol.
or
You can also buy 240sx inner and outer tie rod ends and run them. They are longer (i don't remember by how much though). Mind you, the angle of the tie rod end mounting point is different.
Well i compared s13/s14 inner tie rods and they have different tread and they can't be installed into my fc rack... i was looking maybe e36 could do but they are even shorter than fc's tie rods...
