Few questions on shop items ....
ultimatequinox
Just to check !
http://www.driftworks.com/catalog/products/uprated-clutch-pivot.html
.......fits an R33 GTST also ?
And are the 2 hole decat/exhaust gaskets metal or of the stuff that disintergrates rather rapidly ? Im after decent metal ones like the Nissan original ones or similar.
AND, The release bearing's, Nissan OEM ones, can you supply the ones that are pertruding/pointing up, rather than flat/inverted.
And by chance can you supply sleeves as well, Im after a 14 or 16mm ( preferably ).
Many thanks !:wave:
Just to check !
Many thanks !:wave:
Hi,
Answers below :)
No, it doesn't fit the 33
They are not metal, we use them ourselves and don't have a problem with them. We wouldn't use that material for turbo gaskets, but the exhaust is fine.
Release bearings are OEM Nissan. I've no idea what you mean I'm afraid. What car do you need it for? the R33GTSt?.
Again not sure what you mean by sleeve.
1. Dang
2. Japspeed system, gaskets on decat fall apart pretty quick. I may have the old ones somewhere I think anyway.
3. yes R33 GTST push type, I have pics of the difference, but cant upload ? Not got an external link for pic uploads. Try this maybe though -
Product Image list=
But the type im not wanting is either flat across the face of the release/thrust bearing or slightly inverted ( going inwards/down ) giving a softer pedal feel.
What I AM after is the same dimensions but the face points out/up, giving a slightly harder but more direct pressure on the coverplate springs ( like holding a hammer by the end of a handle rather than half way along etc ). I have part numbers but i do not know which one is the one i want for sure.
The sleeve, well if the link above works you will see at the bottom a list of sleeve part numbers, Im after the 16mm sleeve to go with the bearing im after.
But if you cant help, tis ok, I will find a way. Thanks very much for your time !
