Few r33 GTst bits...
Dunx
Do you do poly bushes for the front diff mounts? or just solid ones?
And curious but do you also do uprated/better hand brake shoes for them as the handbrakes crap even after adjusting.....
Just solid ones. They don't really make it much noisier if that's what concerns you. Basically R32's and S13's used to be solid mounted at the front anyway.
We don't do any shoes I'm afraid. You probably want to check the condition of the inside of your discs where the pads contact as these can cause problems, and throw some standard shoes in there as the are actually more then adequate usually :)
