hi,
i'm going to be fitting some dw control arm bushes to the hub knuckles on my s15 as soon as, i just need to know if once the bush has been removed, does the metal collar also require removal in order to fit them?
also the toe arm hub side bush seems slightly different to the camber and traction arm bushes, but the dw bushes all seem to be the same. does this matter?
thanks in advance
thanks in advance
