Hi, Ive searched around and cant seem to find a definitive answer for this...
When fitting Driftworks subframe polybushes to S13 (specifically not 14), do you need to remove the original bushing outer shell that is pressed into the subframe or do these need to stay in-situ after removing the centre tube and all the old rubber?
I know that solid bushes require you to remove the lot but I dont want to go ahead and start before I know exactly what needs doing..
Eagerly awaiting an answer, many thanks to ya
