tengu
507 hub hp and 750nm at 1 bar boost.
Single turbo, mapped by Robbie at TDP.ie
Built in the summer, done one event since.
Rebuild engine with upgraded conrods,
acl bearings and arp bolts.
Both heads redone with new valve seats, valves and seals.
All new seals and gaskets on the engine
New bosch injectors
Wallbro fuel pump
Aeromotive fuel pressure regulator
Braided fuel lines with AN fittings
Custom turbo manifolds
Gt3582 turbo
600x300x100 Intercooler
50mm wastegate
Oil cooler
Power steering cooler
Rear mounted mishimoto Radiator with electric fans
Water flexible stainless steel tubes
External watter pump
Ecu master black Ecu
Bluetooth can module
Custom trigger wheel
Mac valve boost control
Tablet dash
Bc racing coilovers
Ceramic clutch kit with exedy light weight flywheel
Cd09 gearbox
IRP racing shifter
Fdf lock kit
Momo driver seat
Bimarco passenger seat
Rota wheels
Automatic fire extinguisher system
New knock sensors
Brembo gt brakes
Full drift nascar style Rollcage
Fiberglass everything, including doors, rear boot, rear fenders etc
Battery relocated in the boot
509hp at the hubs
750nm torque
Very conservative map at 1 bar boost tuned by Robbie from tdp.ie
The whole build done in the summer with one practice day and one race event done since.
£15800
New bosch injectors
Wallbro fuel pump
Gt3582 turbo
50mm wastegate
Oil cooler
Tablet dash
Bc racing coilovers
Cd09 gearbox
IRP racing shifter
Fdf lock kit
Momo driver seat
Rota wheels
New knock sensors
Brembo gt brakes
509hp at the hubs
750nm torque
£15800
