Mr Doricar
JDM Loose yo
Sure you all know the specs etc. If not.....
Selling it to concentrate on this 86
http://www.btinternet.com/~driftaholic/motors/ae86/import2doorlevin/
Here's some stuff about the corolla. All honest stuff. It's a pretty good car minus the things that need doing to it. I can get most of the parts for you too.
Bad stuff
N/S suspension top mount gone (£30 from Julian
Down pipes need bracing against exhaust to stop gaskets blowing
Fan heater doesnt work. Think switch is gone
Needs washer jets fitting
N/S Door hinge needs straightening or replacing
Diff leaks oil slightly - New gasket supplied with car
Fuel filler neck rubber perished. Smells fuelly
Handbrakes doesnt lock enough for drifting
Gearbox X-member bush needs replacing (£15 from Toyota)
Comes with Supra 14" rims - Advan 3 spokes sold. Fronts are Yoko A539
O/S windows winder not very good
Diff needs plating up to be good, or can get 2way from guy in Scotland for £300
Good stuff
11 months MOT
5 months Tax
Full safety devices cage (rare now)
Full stainless system from manifold to end (£400 cost me)
New bushes allround. Rear links, panhard rod are new.
New bottom end 1500 miles ago
Good compression engine, quick for standard engine, good oil pressure
New paint job, All rust was fixed by last owner
Fibreglass wings and boot
Buckets and harnesses
New SPAX rear adj. dampers
New front Koni's with SPAX springs
Windscreen replaced (no cracks)
Very light car
£3500 O.V.N.O
Bad stuff
Good stuff
11 months MOT
5 months Tax
Very light car
£3500 O.V.N.O
