D Dave V Member Nov 13, 2012 #1 What pressure will the regulator go up to? is there a blank for when the gauge is not used? Can it be used on non-turbo car? Thanks
Ste333 "The Shoulder" Nov 13, 2012 #2 The regulator will run at 5bar max. It comes with everything needed to fit, including a blank when you're done with the gauge. It can be used on non-turbo vehicles as long as they're fuel injected. Hope that helps Last edited by a moderator: Nov 13, 2012
