GeForce 7950 GT OC 512MB FS sli pci-E HD
Perriss21
Active Member
BFG GeForce 7950GT OC 512MB DDR3 PCI-E Dual DVI
The NVIDIA SLI-Ready BFG Tech GeForce 7950 GT OC graphics card cranks up the graphics horsepower with a whopping 512MB and a 565 MHz core. Power through games with exceptionally smooth frame rates at widescreen resolutions up to 2560x1600, and enjoy ultra fluid, high-definition video playback using advanced NVIDIA PureVideo HD technology. More is better.
NVIDIA SLI Multi-GPU:
Gaming Will Never Be The Same
The revolutionary NVIDIA? SLI??? multi-GPU (graphics processing unit) technology allows you to combine two BFG Tech PCI Express? graphics cards in a single system to scale performance. Taking full advantage of the increased bandwidth of the PCI Express bus architecture, NVIDIA SLI features intelligent hardware and software solutions that allow two GPUs to efficiently work together to deliver earth-shattering performance.
NVIDIA SLI??? can be enabled for every gaming application. However, in order to provide the optimal 'out-of-box' experience for its customers, NVIDIA has also created an extensive set of over 150 custom game profiles which enable SLI automatically and optimize scaling performance.
Description
NVIDIA GeForce 7950 GT overclocked , PCI Express
Included in the box :
BFG GeForce 7950 GT OC 512MB graphics card Quick install guide, DVI-I to VGA dongle, HDTV dongle, Dual 4-pin to single 6-pin power cable, Driver CD, which includes NVIDIA????? ForceWare???в??? unified graphics drivers, Full installation manual .pdf
Minimum System Requirements :
CPU with processor speed of 1.8GHz of higher, 256MB of RAM, Microsoft Windows XP, CD or DVD-ROM drive, 35MB available hard disk space, (50MB for full installation), A 350W PCI Express, compliant system power supply (with 12V current rating of 22A or more), A PCI Express compliant motherboard, A vacant X16 PCI Express slot, Two available hard disk drive power dongles, (smaller floppy disk drive connector is not sufficient)
SLI Requirements :
Pair your new BFG GeForce-based graphics card with an identical BFG GeForce-based graphics card. IMPORTANT: Graphics cards MUST be from the same manufacturer and contain identical GPUs. For example, a BFG GeForce 7950 GT PCIe can only be paired with another BFG GeForce 7950 GT PCIe graphics card. Plug Your BFG Tech SLI-ready graphics card into an SLI-ready PCI Express motherboard. IMPORTANT: The motherboard MUST support two physical connectors that are capable of having two NVIDIA SLI-based PCI Express graphics cards plugged into them. Connect both graphics cards using the NVIDIA SLI connector. Download the latest NVIDIA ForceWare???в??? unified driver with SLI support from Welcome to NVIDIA - World Leader in Visual Computing Technologies
Features at a glance :
Built for Microsoft Windows Vista, PCI Express x16, Superscalar GPU architecture, NVIDIA CineFX????? 4.0 engine, High Speed GDDR3 memory interface, Microsoft DirectX 9.0 Shader Model 3.0 support, NVIDIA????? nView???в??? multi-display technology
GPU :
Bus Type :
PCI Express
Memory :
512MB GDDR3
Connectors :
2 Dual-Link DVI-I, HDTV
Memory Clock :
1430MHz (vs. 1400MHz standard)
RAMDACs :
Dual 400MHz
API Support :
Microsoft????? DirectX????? 9.0 and lower, OpenGL????? 2.0 and lower for Microsoft Windows?????
Vertices/Second :
1170 million
Memory Bandwidth :
45.7GB/sec.
Resolution & Refresh :
240Hz Maximum Refresh Rate, Maximum Analog Resolution at 32-bit color: 2048 x 1536 @ 85Hz, Maximum Digital Resolution at 32-bit color: 2560 x 1600 @ 60Hz​
used for 4 month's Seilling as ive upgraded now:nod:
Everything included as new all in original packaging
£50 delivered:thumbs:
