Hello hope all is well. Sorry about making a new thread with my first post (party foul right?) but I'm having some real trouble with my Driftworks Geomaster2 rear knuckles.
Don't get me wrong, I love them and have them up front too. I'd go as far as to say they represent the single biggest improvement my car has ever seen although the one niggling issue I have is that ever since installing them I have constantly been tearing off driveshaft boots like so:
The problem seems to be that the bracket where the traction rod bolts onto the knuckle is rubbing on the boot when the suspension compresses. Even sitting static there is very little clearance.
The rear end setup is as follows;
180SX (S13) chassis
S15 rear subframe
R200 w/ 5 bolts shafts
Geomaster2 knuckels
S13 PBM coil overs
S13 Cusco camber arms
S13 Cusco traction rods
S13 Yanack toe rods
S15 sway bar
S15 factory LCAs
Rear end setup (ride height was uneven and subframe unrisen at this point):
I have gone as far as to section and box the brackets of the toe rods, this has helped with clearance slightly although still not enough and I loose my driveshaft boots the first time the car squats down under power or I have an off.
Sectioned driver's (RHD) side traction rod bracket:
Raising the car would flatten the traction rod out and help it clear also, although I really would rather not destroy the whole look of the car for the sake of some silly driveshaft boots. I am hoping there is another solution - i.e someone who knows what's up might pop their head in here and say that Cusco traction rods are notorious for not working well with Geomasters and causing this issue Anyone?
cheers and thanks in advance, Jack
180SX (S13) chassis
S15 rear subframe
Geomaster2 knuckels
S13 PBM coil overs
S13 Yanack toe rods
S15 sway bar
S15 factory LCAs
