Gizzmo Boost Controllers
PhilMorrison
Driftworks Owner
Staff member
Having come highly recommended to us, we recently tried a Gizzmo Boost Controller on our Skyline. Not only is it very easy to fit and use, it's also one of the most accurate ways to control boost on the market, and unbelievably good value for money. So we've bought some good stock of them to provide to you with our usual next day delivery where available :thumbs:
Gizzmo Electronic Boost Controller
£197.50 inc VAT
Info:
The Gizzmo MS-IBC is a very high quality multi scramble boost controller. It's a no frills boost controller giving the best accuracy, flexibility and control available, without the high price tag from some other brands.
The MS-IBC is a professional boost controller offering up to 3.5 bar of boost control.
The control unit is a small 55mm width x 25mm in height and 90mm depth, making it very easy to fit within reach without cluttering up the interior.
The read out is a very clear digital display with an over boost warning and a remote button to either toggle the high speed boost change memories or operate the Gizzmo Multi-Scramble feature.
Gizzmo's Multi-Scramble takes the conventional scramble feature one step further. A conventional scramble allows the user, upon pressing a button, to set a fixed amount of over boost and time duration e.g. 3lb extra for 5sec. Gizzmo's Multi-Scramble function allows the user to operate the button again before the scramble time has completed adding the same amount of boost again and refreshing the time duration. All of this plus closed/open loop modes packed into a great looking controller that is so easy to fit and operate.
Features
* Adjustable up to 50lb (3.5bar)
* Multi Scramble Boost
* Remote Scramble/Boost Memory button facility
* Over-Boost warning
* Selectable open/closed loop boost control
* 6 Boost Memories
* 40mhz High Speed RISC Processor
* Black Extruded Aluminium case
* Blue 7 segment LED display
* White backlit buttons
* Real Time digital boost gauge
* Simple 2-Wire Installation
* Suits Internal or External Wastegates
* Comes complete with all fitting
The kit
