Mark_McQ
Active Member
Selling off some guitar gear:
Randall G3 RH150 guitar amplifier head, limited edition urban camo finish model.
100w at 8 ohm
150w at 4 ohm
2 channels, independant reverb per channel. Clean channel has boost function.
Overdrive has mid shift and 2 independant gain settings, which are switch via the footswitch.
Has effects loop with both return and send level controls.
Line out socket.
4 button footswitch to control channel, reverb, clean boost and reverb.
Solid state head, uses 1 x 12AX7 preamp tube for the overdrive channel. I've replaced the stock tube with an Electro Harmonix Gold one.
Head is in brand new condition. Never gigged, only used at room level and very rarely at that. Kept in a non-smoking home.
Randall 412CXM 4x12 speaker cabinet.
320 watts RMS. Made from 3/4" birch.
Loaded with 4 x 12" Celestion custom 80's.
Has switchable 8 ohm mono/4 ohm stereo inputs.
The cab is in excellent working condition. Tolex covering is worn in some places, but structurally the cab is perfect.
Looking for £450 for the pair. I can look into courier costs for interested buyers. Although won't be cheap as they're over 50kg combined.
Digitech GSP 2101 Artist pre-amp.
This is a Digitech GSP 2101 pre-amp which has had a few upgrades done. The GSP series units were all fitted with identical hardware, the main differences were the firmware. This unit has been fitted with the last firmware they did for it, V3.00.00a, which brings it up to the exact same spec as the GSP Artist model.
I've also upgraded it with a 20mhz memory mod which doubles the CPU clock speed, which results in better overal performance, including faster program changes, better expression pedal response, quicker initial boot up, and a faster refersh rate for the display.
The unit has somewhere in the region of 200+ user presets and the same number of factory ones. It's has stereo outputs, can be controlled by MIDI or by using the Digitech control pedal for it.
The unit uses 2 x 12AX7 valves for the overdrive and distortions.
Comes with the user manual too (Although you'll need to download the GSP Artist one on PDF from the Digitech site for an updated patchlist to reflect the firmware upgrade.)
£80 for this. Can get a courier price on this too if needed.
Krank Distortus Maxmius distortion pedal.
This is a overdrive pedal designed around the pre-amp circuit used in Kranks amp head. It's a fairly crunchy overdrive, and sounds excellent when used to drive an already distorted amp. In excellent condition, boxed with manuals, barely used.
These retail at about 140-ish, I'm after £80 posted.
Electro Harmonix Small Clone Chorus pedal.
Easy to use chorus pedal. Same pedal used by Kurt Cobain on 'Come as you are' (So you know how it should sound). Has depth and rate controls.
Boxed with manuals. In brand new condition, barely used.
£40 posted
100w at 8 ohm
150w at 4 ohm
Line out socket.
£40 posted
