Mark_McQ
Active Member
Selling 2 pieces of rack gear that I've been using with my guitar setup.
First up is a mid 80's Ibanez HD 1000.
This is a delay and harmoniser unit. Can do pitch shift/harmony effects. It's a non-intelligent harmoniser, so it doesn't track by key. Can shift from roughly 15 tones down to 15 tones above. (3 tones more than an octave up and down).
Also has modulation controls to give the harmonisesed line a bit of movement, determined by the speed and width controls.
The delay mode can do up to 504ms and can also be used to produce chorus, vibrato and flanger effects too, by setting the delays correctly.
Unit has 1 rear inputs, and 2 outputs for mono/stereo use.
The plug has been swapped for an IEC connector because I'm running it from a power conditioner. To use from a wall socket, you just need to put a regular plug on or alternatively use an IEC kettle-style lead.
Second unit is an Alesis Midiverb 4. Stereo reverb/delay unit. Produces some very lush chorus and flange effects too. Has many types of reverb from room to cathedral style.
Also has both mono and stereo pitchshift functions with delay parameters for harmonised arpeggio sounds. (Search youtube for 'Steve Vai Ballerina 12/24' for a good example of that).
Like the Ibanez, this is also non-intelligent, so harmonises fixed intervals from whatever is played.
Very easy to program, all parameters are very straightforward.
Has over 100 presets and 128 user presets.
Looking for £80 each or £150 for the pair. Postage would be £10 each or £15 for both together.
Would swap either unit for a 24 fret AANJ Ibanez RG neck. Doesn't matter if it's a locking nut or regular. Would prefer a bound neck.
