handbrake problem
badassae86
hey there ummm...i'm not sure whats going on but seems like when i pull on my handbrake only one side of my handbrake is locking up seems like one side is not....anione have a clue on how to fix that.....
mis worn pads? streched cable. could be a number of things. if you reverse at a decent speed (15mph) and then yank the yankbrake hard till you stop it will centre it up. might have better luck then. other wise just re-ferb the system - new discs, pads and cables :thumbs:
Most likely siezed handbrake cable; you may as well replace all three cables.
Could be a siezed handbrake mechanism on the caliper also.
would a Hydraulic handbrake be a worthwhile addition, because of its ability to "flyoff"
i ask this as this is something i was considering when i ditch the abs and re do the brake system with a bias valve
