Help identifying this diff
Jayster
Is anyone able to shed some light on what car this diff will fit into?
It was sold as for a nissan r200 diff however it does not fit.
I had a customer who recently bought something similar, turned out it was for an R180, so S12's and......others
I took some measurements
Measuring from front to back, as if the diff was fitted the biggest part where the crown wheel bolts to is around 170mm, the thinner bit is around 105mm, the width off the diff not including the bearings is 100mm and the diameter of each end where the half shafts go in is 30mm.
