Jtrevittmx5
Hi, I'm trying to remove my bilstein shocks from my mk2 mx5 to fit my HSD monotube coilovers, having watched the video on the driftworks website I thought it would be quite easy for myself as I'm a mechanic by trade in the Motorsport industry, however I came across a problem quite quickly, on the top of my shocks a rod comes out from the top mount and has an Allen key shaped hole (5mm). This rod essentially means that I cannot take the damper out in the way shown in the video as it stops you from leaning it out. I have copied the rest of the procedure, the spring compressors does not compress this damping rod but can be pressed down by hand with some difficulty, so was wondering what people would suggest.
thanks, Jordan
thanks, Jordan
