HICAS Eliminator
nick26
Alright guys
Recieved the above this morning, cheers for quick delivery...quick Q, im guessing this is pretty straightforward to fit??
reason is i reckon i will just get the MOT garage to slap it on before getting my car re-trested. (It failed due to rear steering arms)
Yeah it's a relatively straight forward thing to fit. The only difficult bit is removing the outer ball joint in the hub knuckle. This can be a bit of a horrible job for DIYers, as they rust into the hub. Worst case is that it needs pressing out with a press. A garage should be able to handle it..
Don't forget the ball joint has a circlip on the back of it before it can be removed :).
Hi Guys
I dropped the car and kit at the garage this morning, but just recieved a call saying that they couldnt fit it becuase the power steering fluid runs into the rear arms they would need to block this off, and didnt have any blockers'
Im not sure exactly what they mean, any ideas? I just assumed the kit would include everything required to sort it, cheers for any help.
