HICAS Lock kit
Just a quick enquiry does your HICAS lock kit £85 one
come with everything needed i.e fittings to connect the pipes together?
For a 93 180sx with super HICAS (if it makes any difference)
How much is postage?
Cheers
It comes with the mounting hardware but for the hydraulic pipes you don't want to block them anyway. Just use a short length of the left over rubber hose to loop the metal lines, creating a big power steering cooler under the car too! Kill two birds with one stone. :)
Postage within the UK is £8.50 next day delivery.
Cheers so basically the bits to loop together are all ready on the car so i wont need to go looking for adaptors etc
i had a quick look under the back of the car and seem the flexi pipe ill go back and im sure everything will fall into place.
i assume the rubber pipe has the same union on each end?
Where the metal line has a rubber line hoseclamped over it, running to the rack, you can just disconnect the rubber lines and run one of them to the other metal line, hey presto, a loop.
I'm working off memory so if my description is not 100% then I apologise, but you get the idea. :)
