Cowpatmatt
Active Member
Hey,
I ordered the Driftworks Hicas removal kit for my Z32 a while back. Just got round to fitting it and there are bolts but no nuts.
Its the nuts for the bolts that hold the hub to the arm and the center bracket to the arm.
So could you send me the nuts please
Just to add a little feedback about the kit, The quality of the powder coat it a bit dodgy as it comes off easily. Where the bits have been laser cut the scale has not been cleaned off so the powder coat will not stick very well.
Also with the arms I think you should TIG weld the bracket on rather than MIG as its a small weld. It will look better and be stronger.
I am not complaining, just thought a bit of constructive criticism would help you out.
Just as a side note I am a welder and fabricator so I talk with experience.
Thanks
Matt
Thanks
Matt
