hks camp
astra_coupe
having no luck
can DW get these in? whats the price considering exchange rate is pretty shit at the minute:( delivery time?
would it be here this side off xmas at all? if not its gonna be the wing im having the missus pay for...
thanks sim:)
Yep, no problems! All in stock at HKS Europe so we can get them within a week. This side of Xmas is no problem! :thumbs: Here's the breakdown of prices for the various bits, I'm not too up on the CAMP stuff so here's just a list of what you can get, if you've got any questions let me know and I'll check with HKS!
CAMP 2 - £355
Nissan Consult Harness £21
CAMP 2 Remote Controller £21
CAMP 2 Remote Controller Receiver £32.50
I/F Unit £72.50
Meter Harness No.3 £15
Temperature Sensor Set £50
EGT Sensor Set £105
Pressure Sensor Set £105
Boost Sensor Set £105
Fcon Communication Cable £6.50
Just so that you know, the remote and receiver are spare parts (one of each is included in the Camp2 unit) and you will need a monitor that can display an NTSC signal but I think most monitors can do that now.
The sensors listed are all for use with the I/F for displaying extra data that cannot be taken from the OBD port.
The Nissan Consult harness is for Nissan cars which don't have OBD but have the NIssan consult port (pretty obvious eh?)
Any questions throw them at me or Bon Bon and I'm sure we can help.
thanks for that was thinking thats well harsh having to pay for the remote control and the reciever... cheers for clearing that up for me was so close to ordering the wing :thumbs:
so all i need is the camp iself and the nissan consult cable? read they use the cig lighter to work but i dont have one in my car can these be hard wired in safely?
will place my order tommorow whats the final amount inc postage?
What car is it for? I have the list for compatibilities etc here at the office.
Yeah should be no problem with the consult harness. You don't need a cigar socket in this configuration either which is good for you.
As standard for an S14, the CAMP will read and display:
Vehicle Speed
RPM
Water Temp
Ignition timing
A/F correction trim
O2 Sensor Voltage
Air Flow Meter Voltage
Injector Duty Cycle
It will display but give a false reading for throttle position.
Set the unit up as Nissan 1 in the base ssettings and your ECO correciton figure to 1480
Using the optional I/F unit and the appropriate sensors you can also monitor
Water temp
Oil Temp
Oil Pressure
Fuel Pressure
EGT
Boost/Vacuum
you could of course use the water temp sensor and use it to measure anything like ambient temperature, inlet air temperature etc.
Any other quesitons, just let me or Bon know
thanks for the info just out off interest can it read fault codes too?:worthy::smokin:
got my screen sorted out too thanks bolf:thumbs:
bon just to say ill call tommorow with my details etc but id like to order...
CAMP 2 - £355
£376 just need to know what postage will be and transfer it from the missus account to mine...
thanks sim and his poor missus:D
do these work on facelift s13s? this sounds better than getting a load of gauges :)
Indeed, cluttering the dash with lots of gauges is no longer necessary with this unit as you can display it all through a single monitor.
I don't have the CA powered cars listed on my list but that doesn't mean that it won't work. I can't remember, does the car have the nissan Consult port?
If it doesn't, you can still use the Camp unit with the I/F box and auxilary sensors but you won't be able to get the data you normally would from the OBD or consult ports.
if your car is after 1990 then it will most likely have one according to google...
one off the reason why i wanted a hks camp is it takes away the need for all the gauges etc etc
