HKS GT11 Wastegate "BRAND NEW"
op141
HKS GTII Wastegate, Brand New Boxed, includes additional wastegate springs for different base boost starting points, KG/cm2 0.6- 2.1,PSI 8.5- 29.9, Valve Dia-60mm, £475 No offers. (RRP £675), Tel 07979903989 ( Bristol) ( best to ring as I will only access emails once a week)
http://www.hksusa.com/images_products/L_2067.jpg
The HKS GT II Wastegates are the latest in wastegate technology. They feature a lower body cast from stainless steel and an anodized purple upper case machined from billet aluminum. The GT II Wastegates weighs approximately 2/3’s the weight of the original GT Wastegate and are significantly smaller in height and width. Their compact size combined with the GT II’s V-band inlet and outlet flanges allows for versatile mounting in tight spaces. --- GT II Wastegates also include additional wastegate springs which allow for different base boost level starting points. A special tool is also included which allows for the simple installation of the extra wastegate springs.
HKS GT II Wastegates are available with either a 50mm or 60mm stainless steel valve, and have base boost levels that range from 0.8kg/cm2 (11.6PSI) – 2.0kg/cm2 (29.0PSI) and 0.6kg/cm2 (8.5PSI) – 2.1kg/cm2 (29.9PSI), respectively. Like all HKS Wastegates, boost can be raised above the base boost setting by using an HKS EVC or VBC boost controller.
