A AndyH JDM New Member Feb 22, 2017 #1 Right, I've got an HKS SLD type 2 for my jzx100 auto. Of course the diagrams are all in Japanese, has anyone installed one if these before? Or can point me in the right direction? Thanks in advance! Andy. Sent from my SM-G930F using Tapatalk
jon07043278 Well-Known Member Feb 22, 2017 #2 So i'm guessing 1JZ then? I will take a look at mine and give you the wire colours. Forgotten which now.
A AndyH JDM New Member Feb 22, 2017 #3 jon07043278 said: So i'm guessing 1JZ then? I will take a look at mine and give you the wire colours. Forgotten which now. Click to expand... Yes mate! Thanks alot! loI think I've deciphered which ecu diagram I need to use... but I can't read Japanese Sent from my SM-G930F using Tapatalk
jon07043278 Well-Known Member Feb 22, 2017 #4 White -> Turquoise / Black Stripe From Engine (Connector 3) Yellow -> Turquoise / Black Stripe To ECU (Connector 3) Red -> Black / Red Stripe (Connector 1) Black -> White / Black Stripe (Any) (Connector 4) So the turquoise wire needs to be cut and the end from the engine connected to white and the end to the ecu to yellow. The red and black wires just need to tap off the wires (power and ground), so just peel some of the insulator back and solder/twist the wires.
