How much are r154 boxes worth nowadays?
milez
Active Member
How much do the r154 boxes go for now? Complete with shifter, bellhousing from a mk3 7m supra and say clutch, flywheel and starter.
Cheers
Depends on mileage, condition, service history etc etc. Bell housing can go in the bin as its useless, same as the clutch and fly as it will probably be going onto a JZ which uses different bits.
Far too much! Haha most good condition low mileage I see are around £1500, but you can order a new one direct from japan for £1550 + shipping and taxes?
From a mk3 supra, not an enormous amount for a few reasons, the bellhousing wont suit anything (few hundred from toyota), it doesnt have the extended shifter so doesnt suit alot of cars, it will be old and probably high miles.
That being said, its probably still several hundred, which is likely enough to cover the cost of a mk3 for breaking lol
At the very minimum 500, but you could probably get a good bit more. The shifter needs modified in most cases regardless of what it's going into. Unless it's a chaser/soarer etc.
