HSD coilover springs.
Dex
kut!
can you supply shorter front springs with the same spring rate?
tried slamming a s13 on 17's with 215/40/17's but it just isnt low enough :(
Have you removed two of the locking collars?, you can just leave the one locking collar holding the bottom bracket on. (make sure you use the big spring seat collar)
yup done that. dont want to wind up the preload more then it is really
Adding preload will raise the car.
So, you have the 1 collar locking the bottom mount and seating the spring?
I can get you some shorter springs (175 would be ideal I guess?) if you want but they'll be ordered in and £80 a pair. :)
@kam, yessur!
@bon, not my car, my mates ill ask him when hes over tonight, are those the same springrate? how long are the normal ones?
200mm normally, I could get whatever rate you wanted so yep the same rate, just let me know how old his kit is so I know if it's got 8kg or 7kg front springs.
ahh there it is! wrong topic haha!
what i ment to say was: According to my friend, its low enough, so ill wont be needing the shorter springs :) good to know tho, for future reference
i have these coilovers now :D how long does it take you guys to get the springs in? and how much shipped to holland :D
i think the 175 would do the trick, (or can you get some 150's?) ehmm not that hard, now idea whats on there atm really. guess 6 or 7 would be right
its for a daily that gets to a couple of driftydays a year, i liked my old 8/6 apex's
