HSD Monopro tune help
Reznik
Hi all,
I have a BMW E36 with HSD Monopro coils with springs 10/10 that i use just for track.
At the rear the setup is perfect with rebound settings 4 clicks below max.
At the front i set the preload at 0 but right from the start i felt the coils were too soft, with rebound 6 clicks from max. So i adjusted the rebound to max.
In terms of hardness it got better but became a little bit "jumpy". However the front still travels a lot up and down.
What can i do next to avoid all this travel? In practical terms what happens is that on the track, if the tarmac has little jumps, the front end is constantly going up and down when the rear is "flat".
Thanks in advance for the help!
Are you talking about the damping adjustment screw or the pre-load on the spring?
Pre-load on the spring at the front is "zero". By this i mean i'm not compressing the spring. Just tight enough so that it doesn't rattle.
What i've adjusted to max setting is the adjustment screw on the shock that adjusts the rebound (i think it's called like this).
