F
- Fezcock -
Guest
My HTC Touch HD - Left over from when I upgraded to my HTC desire
Basically, I need moar money for car bits going towards funding coilies for the E36
It has been fully refurbished by myself - New chassis, New case and a new screen (I did all this with the idea that my girlfriend would have the phone, but after all that the git didnt want it! :furious: It Is unlocked to any network although it still flashes up orange when you turn the phone on and With the exception of a few tiny blemishes which ill outline in a sec, the phone is MINT
I have the original box that it came in as well as the hands free headphones etc - the only thing that is missing is the Windows Mobile CD - When you plug your phone into your computer, you can dowload everything you need in about 5 minutes so its not a problem tbh
Comes with an 8gb Mico SD card too
There is only one stylus with the phone (my mum lost one!)
Specs Taken From HTC Website
The Badpoints -
1) The on the back there is a section about 1mm square that i moved up with a screwdriver by accident when I was refurbing the phone
Pictured Here - Slightly to the right
2) In one corner of the screen at the top right, there is a TINY amount of fogging, again no more than 2mm square - this was due to having to use superglue to put the new screen onto the chassis (due to the construction of the phone)
I have tried to picture it but its almost impossible to see when the phone is turned off and impossible to see when the phone is turned on
More Pics
Model HTC Touch HD™ T8282
Processor Qualcomm® MSM 7201A™ 528 MHz
Operating System Windows Mobile® 6.1 Professional
Memory
ROM: 512 MB
RAM: 288 MB
Dimensions 115 mm x 62.8 mm x 12 mm
(4.358 in x 2.4722 in x 0.47 in)
Weight 147 grams (5.185 ounces) with battery
Display 3.8-inch TFT-LCD flat touch-sensitive screen with 480 x 800 WVGA resolution
Network1 HSDPA/WCDMA:
Europe/Asia: 900/2100 MHz
* Up to 2 Mbps up-link and 7.2 Mbps down-link speeds
Quad-band GSM/GPRS/EDGE:
Europe/Asia: 850/900/1800/1900 MHz
(Band frequency, HSUPA availability, and data speed are operator dependent.)
Device Control
* HTC TouchFLO™ 3D
* Touch-sensitive front panel buttons
GPS GPS
Connectivity Bluetooth® 2.0 with Enhanced Data Rate and A2DP for wireless stereo headsets
Wi-Fi®: IEEE 802.11 b/g
HTC ExtUSB™ (11-pin mini-USB 2.0)
Camera
Main camera: 5 megapixel color camera with auto focus
Second camera: VGA CMOS color camera
Audio Built-in 3.5 mm audio jack, microphone, speaker, and FM radio
Ring tone formats:
AAC, AAC+, eAAC+, AMR-NB, AMR-WB, QCP, MP3, WMA, WAV
40 polyphonic and standard MIDI format 0 and 1 (SMF)/SP MIDI
Battery2
Rechargeable Lithium-ion polymer battery
Capacity: 1350 mAh
Talk time:
Up to 420 minutes for WCDMA
Up to 480 minutes for GSM
Standby time3:
Up to 680 hours for WCDMA
Up to 440 hours for GSM
Video call time: Up to 140 minutes
(The above are subject to network and phone usage.)
Expansion Slot microSD™ memory card (SD 2.0 compatible)
AC Adapter Voltage range/frequency: 100 ~ 240V AC, 50/60 Hz
DC output: 5V and 1A
Special Features FM Radio, G-Sensor
The Badpoints -
More Pics
