razi-islam
Brand new...not used...change of plans so it has to go
the spec:
T3/ T4 OE TURBOCHARGER
STAGE III WHEEL
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8" NPT OIL INLET
T3 / T4 FLANGE
FITS T3 AND T3/T4 MANIFOLDS
5 BOLT FLANGE
.50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
CAN EASILY PRODUCE 25 POUNDS PER SQUARE INCH OF BOOST
TURBINE WHEEL: EXDUCER: 2.48" MAYOR : 2.89"
COMPRESSOR WHEEL: EXDUCER: 2.07" MAYOR : 2.36"
EQUIPPED WITH A HOLE FOR INTERNAL GATE APPLICATIONS SO YOU CAN USE THIS T3/T4 WITH EITHER AN INTERNAL ACTUATOR OR AN EXTERNAL GATE
no sensible offer refused
any questions PM me or id prefer if you email me on ec03ari@brunel.ac.uk
RAz
the spec:
STAGE III WHEEL
3" INLET DIAMETER
2" OUTLET
1/8" NPT OIL INLET
T3 / T4 FLANGE
5 BOLT FLANGE
.50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
RAz
