Hydraulic handbrake lines
Yes you will need both. On most cylinders the port at the back in the IN and the port at the front is OUT.
So how does it join the old brake copper lines in back brake? car is s14a btw. will it use a little T pipe or sommat?
I haven't used the dw lines but at a guess.
Chop the copper pipe in 2. Fit a male end on each one. Flare pipe. Attach dw hose to each one then the other end to the cylinder.
It replaces the rear line, so input from the front (master cylinder) and output to the rear (t-piece), hydraulic handbrake in the middle! :)
and if anybody needs fitting they are hydraulic lines not brake lines and the fitting are 1/8npt - wateva your mc fitment is.
on mine it was 1/8npt to m10x1
Cheers guys, i've found a epic thread =) its got everything i need to know lol
http://www.driftworks.com/forum/faq-new-members-please-read/76446-hydraulic-handbrake.html
final look will be like this?
a quick question, does the DW hyro kit comes with T piece and everythings for plug n play? :D
Yes it comes with all the fittings :)
You use the T that is already on your car.
cheers for the links man, I didn't even think about mot till now with a hydrolic handbreak. that would have been stupid of me!
