hydro handbrake
sammysideways
Active Member
im expecting that ill prob wont have any joy but thought id ask. the hydro handbrake fitting kit i guess thats for dirty nissans? or can you get/do one for the e36?
btw good spot james, e36 tourings skid good. im well happy:thumbs:
I reckon the only trouble you might have is getting the plate/bracket made up to hold the lever - you can get the lines cut and bent to size... shouldn't be a big job...
the bigger problem might be the diagonal brake system many bmws have.
change to front/rear or use 2 handbrakecylinders...
Should fit fine dude, S14 and E36 are a similar length so I'd expect it to be fine.
E36 just has a front-rear line, out the master cylinder to the rear t-peice. Shouldn't be any problems.
sorry jeek, cleared.
missed this..cool so if i order the hanbrake and fitting kit for s14 it be fine? what if its to short or sumat though?
