i want some springs
i have cs1's on my s15 and the wheel is mega close to the spring. cant space the wheel out anymore as it will stick out to much and look gay so i want shorter springs.
the cs1's come with 200mm springs i want some 150 or a touch shorter springs. think they are the later cs1's so will have a spring rate of 7.
so i want some springs that are 7kg in weight, have an internal diameter of 65mm and have a free length of 150mm or shorter.
whatch got??
Nothing in 150 I'm afraid, 175 is the minimum before you start to get spring in your particular setup bind really.
What size wheels are you using?
17x9.5 not sure on the ofset was suposed to be 25. Wants 9's on the front really but I've got no chance of getting some to match.s15's have poxy small arches.what do you mean by spring bind? Just so we are on the same page so to .speak.
Sorry just seen this, spring bind is where the spring runs out of travel and the coils hit each other.
You'll need narrower wheels or arch mods :)
