im haveing idle issues
stevie brown
(backstory) i just bought a toyota mark 2 with a 1jz-ge and when i looked at it it ran and idled fine and on the test drive it was perfect, i have had the car for 2 days now here in okinawa japan and im haveing issues
when i start the car it runs good and the idle is a little low at about 600rpm then when im comeing to a stop it ends up drop to 200rpm or it shuts off i have tryed finding a vacume leak and couldn't find one i also took off the postive lead on my battery to see it the ecu(its stock) could maby relearn how to idle properly it seemed promising. idleing at about 700-800rpm then on the test drive it went back to it 400rpm idle and did the same 200rpm idle stop and even shut off if you have any idea on what it is, it would mean the world to me
